Dewalt 625 Guide Bushes
Mdotflorida
7 Nov 2003
South Wales
Does anyone know if a set of guide bushes is available for this router or will I have to go the Trend unibase route ?
A search of the web and and the Dewalt website didn't turn up anything.
Jeff
A
Anonymous
Guest
You will be better off with the unibase anyway as this ensures that the cutter is in correct alignment as i sent an email to trend about the same thing and here is the reply:
Dear Derek
Thank you for your email regarding the trend unibase.
Please be advised, if you wish you are able to use your existing 30mm guide bush that came with your router, however the advantage of using the trend unibase is that you receive a line up bush and 2 line up pins with it, this will enable you to be sure that your cutter is lined up correctly with the guide bush and not at an slight angle. This will cause the joint to be out.
Regards
Dave Morris
A
Anonymous
Guest
Isn't the DeWally the same as the CMT, ELU, MOF stuff? Mebbe something that fits the CMT Axminster sell will do you?
