jadboog":3cl2xj7c said:
Scrollerman - I appear to be getting somewhere.
The noise happened whether there was a blade or not, so I eliminated that from my investigation. I opened up the saw to reveal the linkage between the motor and the bottom arm, checking the tightness of the fit to no avail. In the interest of further elimination I disconnected the linkage to the motor and the noise persisted (thereby eliminating the arms as the source of the fault).
Hello James,
Running a scroll saw without a blade is bound to give rattles and noises purely because the blade clamps are pivoted and will flop around like crazy !
The rear pivot points/springs of the arms will also rattle if there is any play in them that is generally taken up by a tensioned blade.
I really don't understand how the noise you hear can be the same with or without a blade as not having a blade installed, (for the above reasons), would be totally
different and much noisier.
Anyway.
The motor sounds fine as does the motor with the 'Exzenter'on the shaft.
For Exzenter read counter-balancing weight.
The counter-balancing weight is there to help counter balance the weight of the
arms so testing without the arms attached is bound to give some vibration by it's
very nature. If you are sure the exzenter is solidly fixed to the motor shaft then
that is not the fault.
Moving the Cam position laterally on the motor shaft should only be done when
there is an issue of vertical alignment between the movement of the bottom of the
blade and the top but that is another issue which doesn't apply here.
Your problem is a strange one and doesn't conform to normal scrollsaw physics
judging by your description of what works and what doesn't.
I'm at a loss to know what is wrong given your symptoms/replies without seeing the
saw first hand.
You could try re-assembling the saw and use the tried and tested engineers method
of using a long screwdriver to 'listen' for where the rattling/vibration/knocking is
coming from.
Start the saw running and with a long screwdriver, place the handle of the
screwdriver against your ear.
Place the tip of the screwdriver against various places (non-moving of course) on
the scroll saw and listen for where the rattling/vibration/knocking is loudest.
This will at least give you a good idea of the location of the fault.
Good luck.
Scrollerman
