dark aged look to oak for church cabinets
RobinBHM
17 Sep 2011
Wst Sussex
Hi,
I have some oak cabinets to make for a local church.
The architects have specified a finish to match the dark aged colour of the church pews.
I thought I might try Vandyke crystals to stain and then use microcrystalline wax and buff
The cabinets are being made in character grade european oak. Style is face frame, with lambs tongues door and flat solid panel.
Carcases are veneered oak plywood (I think the carcases can be sprayed in clear eggshell lacquer).
TIA Robin
I did wonder about fuming, I guess I could make a softwood frame and pin some polythene to it. Some of the front frames are quite large, about 2metres wide, would the fuming process still work ok? I suppose it would need a few pots of the ammonia.
Does the fuming reach around the edges of the panels, I wouldnt want the risk of the panel shrinking and exposing untreated oak?
cheers Robin
the fuming would still work on large items- it is just a matter of standardising what you get on multiple items- similar amount of ammonia, same timescale, and ideally the same temperature.
It works on line of sight, so if the timber prevents the fumes reaching a part it will not colour it. For example if you cross 2 pieces in the fume tent, it will leave a stripe.
I would fume the panels before assembly
Fuming might be the solution as marcros suggests. I've used box trailers and Luton body vans as fuming chambers for large stuff - it saves rigging up a tent with softwood and plastic, especially if you already have a vehicle you can utilise, or any other suitable chamber. .880 ammonia is what you're after and it's available from most polish retailers, e.g., Rydenor. After that it's just a case of putting some ammonia in a shallow dish and experimenting with exposure time to get the darkening you're after. Worth being aware of is that the oak, once fumed, will have a green tinge, but this disappears as soon as you apply a polish.
If you go with dye, e.g., walnut (Van ****) you might prefer an oil or spirit based version as these penetrate the open pores of oak better than water based stuff which tends to bridge across the open grain leaving the bottom of the furrows or pores undyed. You can help overcome this by adding two or three drops of washing up detergent per half litre of dye because this reduces the water's surface tension.
Lastly, best of all might be a pigment stain because the pigments lodge in the open pores of the wood which might go some way to replicating the grime that's already worked its way into the existing church furniture you're trying to match.
Dyes don't contain pigments, although it's hard to tell dye from stain here in the UK just from the label on the container because UK manufacturers typically use the words dye and stain interchangeably. If the instructions on the liquid's container tell you to stir the colourant regularly during application you're working with a (pigment) stain. Lack of such guidance indicates a dye.
As to a final finish, it's hard to say without seeing the originals, but if these are a century or more old they're most likely to have been finished with wax alone, or perhaps a sealing coat or two of lightly applied shellac followed by wax. They may even have been finished with boiled linseed oil and wax, although spirit varnish is a possibility. Whatever the base coat might have been, if any, I'd be somewhat surprised if wax wasn't part of the job somewhere down the line. You could do something similar, e.g., spray a light coat or shellac or lacquer just to seal the grain followed by a wax of some sort. Slainte.
Many thanks to both of you for all the advise -its much appreciated.
A coat of lacquer sprayed on first to seal and then waxing sounds a good idea.
I think I will experiment with the ammonia and see what colour it achieves and compare it to stain / dye.
Cheers Robin
