HappyPixie
Hi all
I turned a piece of burr elm with the lumpy bark side left lumpy.
The cut faces were sanded through the grits to 600 and I added four coats of Danish oil. The oil application was: wipe on generously, wipe off all excess after a minute or two, leave for two or more days, cut back gently with 0000 wire wool and apply next coat. The final coat was rubbed on with 2400 MicroMesh and wiped clear with a soft cloth but when it dried a smeary surface in a circular pattern is visible. It feels smooth so I suspected I could polish over and it would disappear. I applied a small amount of Microcrystalline wax and used a lambswool mop on a drill to smooth it and buff it. The streaks are still visible and the surface is now slightly more glossy.
Can anyone say what I did wrong? Do I need to remove the Microcrystalline wax before I take the 600 grit back to it? Or should I lightly use a furniture scraper to flatten the surface? Is there a chemical I could use to smooth out the surface?
Very frustrated! Here is what the sears look like:
Any suggestions would be very helpful.
Steve
Steve
