Dangermouse":3g23lriq said:
My take on brakes is that the rules are a brake has to stop the machine in 10 seconds. Now imagine your hand has caught in the blade / dado of a table saw, then count for ten seconds, taking into account if you could hit the off button while your hand was being mangled. I don't think such brakes are as wonderful as they are cracked up to be.
I kind of got the impression it was more so that once the machine is turned off, it's 'safe' within a shorter period of time. In particular in a commercial environment, if people turn the machine off and walk off, someone else coming along afterward who doesn't hear the noise of the motor (because it's been stopped!) is less likely to lean over and injure themselves on the still-spinning blade.
Just from a single-hobby-user-in-the-garage point of view, I'm quite happy that my table saw stops moving pretty quickly - it means I'm not tempted to grab the workpiece from behind the blade before it spins down.
(As to housing joints and so on, I've only ever used a router - an electric one! - and a plough plane, and the router is certainly easier.)
