Cutting groove with rebate cutter on router.
RossJarvis
20 Aug 2013
Petersfield, Hampshire
Is there any reason not to gut a groove across the end grain in oak with a bearing guided rebate cutter? I was thinking of adjusting depth of cut by going down the bearing sizes.
Hand-held, not in table.
Depends on how wide the wood is, it should be possible on a wide plank or ganging up the pieces.
Set up and test on some scrap and see if you feel comfortable.
The only problem I see is how to stop the speltching. If that does not matter then it should work just fine.
Thanks for the help guys, particularly the speltching, must remember to go one way not the other, only one edge will be seen.
(It's amazing what websites you get when searching for "speltching" :oops: )
