About 18 months ago I had a 2" thick bubinga coffee table top made which eventually cupped. I finished it with finishing oil and put quite a few more coats on the top side then the underside. I guess this was the root cause that led to the cupping.
How can I make it straight again without cutting it up and starting over?
I was thinking of using two T shaped steel profiles inserted into a routed groove on the underside.
I was also wondering if there was a simple way to fix the MC/ release the stresses to make it bend back the right way before adding more finishing coats (if that is indeed the problem)
Vikash
Vikash
