Biliphuster
So, as I was working on something recently I needed to join two boards together but I knew they would be getting rough treatment, so I thought about doweling them, or ideally tongue and grooving. Alas, whilst I have a plow plane I have no way to make the tongues unless I want to cut them out as super long stubby tenons. I had seen recently in "Modern Practical Joinery" a joint for such an occasion with a loose tongue floating in a double groove. Closer inspection of the image showed that the tongues were cross grain to the boards they were joining. This seemed like a good idea so I gave it a go.
I first planed up a small board to the right thickness (1/4") to act as the tongue. The board was 4" wide and I wanted to join a stretch of 20" so I sawed some sections from the end and inserted them in the grooves. The fit was not great for all of them, but I made sure the one at the front was tight as it would be exposed.
The other component had differently oriented boards, so I could cut the tongues on the end of the boards and they were only 8 inches or so. The glue up was a little wacky though
The I traced a grid on so I could draw a symmetric curve
Some shaping with drawknife and spokeshave
And complete
With a close up of the finished joint
Edit : Looking at the pictures I see it still a bit dusty and the neoprene I used as washers has got everywhere!
And complete
