Cross cutting
radial arm saw.
but mitre saw, or circular saw would do as good a job. I would avoid using the jigsaw for it personally. The limitation with the circular saw would be short pieces. But you could also use that tool for other tasks.
26" x 6tpi Tyzack Sons and Turner or 22" x 10tpi Spear and Jackson 88 for thinner stuff.
Doing some fence-building over the last few weeks, I found the only thing I had that would cross-cut 6" x 1" and 4" square tanalised sawn softwood without jamming up instantly was the old gardening bow-saw. Surprising how accurately you can cut with one of those after a bit of practice. Oddly, the Roberts and Lee Dorchester 26" x 4 1/2 tpi rip (which is set for dry hardwoods) worked OK, but I did have to wedge the longer cuts open.
Surely this would mostly be dictated by the dimension of the timber being cut?
I use a mitre saw for moderate widths and a table saw or track saw for anything bigger. Convenience and safety being the determining factors.
A radial arm saw would be a good intermediate between the above options but they scare me and don't tick my safety box. That said, I need to get over this as I'd love to get one.
I use a 305.. sliding mitre saw ( actually a axial glide but same sort of thing ) which gives me really accurate cuts up that width.
I also have a radial arm saw that will do the same width but I also do not feel safe with it and no longer use it.
For wider stuff I use a track saw.
The decider is often length. The sliding table on my panel saw has a scale that only measures down to about 120mm. Anything shorter than that becomes difficult to hold safely, so for smaller components I'll often cross cut with a hand saw on a bench hook and clean up the cut with a shooting board, or if there are a lot of small pieces to cross cut then I'll cut them on a bandsaw and clean up on a disc sander.
Another cross cut option in my workshop is a hand held circular saw running in a track, but again the length of the component becomes an issue, if they're too short they disappear under the track itself.
For really short pieces it has ( in my opinion ) to be the bandsaw.
Radial arm saw = hand to close to blade
Mitre saw = hand to close to blade
Table saw = <emoticon for EEK !!! >
Table saw =
Like this :D
Table saw =
Like this :D
That's brilliant! That's the perfect emoticon for so many workshop experiences, from a bandsaw blade suddenly breaking to when a glue-up starts to go wrong!
Emoticons are so easy to nick
Cross cutting. A decent hand saw.....mitre saw......table saw....never a jig saw, the most inaccurate saw ever.
    1.8 KB
    63.4 KB
    99.7 KB
For cross-cutting I use a bandsaw, a circular saw and a handsaw.
For ripping I use either a bandsaw or a table saw, and for long pieces (6 feet +) a circular saw.
