Corn on the cob pen turning?
Steve Blackdog
24 Mar 2008
Cumbria
Has anyone turned corn cobs? I had my first setback this evening, when I found the dog had eaten one of the 'blanks' I'd been drying out. (I suspect it will go right through him!)
How hard do they get? Mine were woody, but still soft enough for the dog to eat (hammer). I had mine next to the wood-burner to dry them quickly, but is that the right way to season them?
If anyone has any pics, I'd be very interested.
Steve
Steve,
Best of luck on your endeavours with the corn. I tried several times but gave up and ended up buying the cobs from Stiles and Bates! I dried mine uncovered in the fridge, stopped the mould after I had eaten the goodbits and washed the garlic butter off! Very good dehumidifier the fridge! Once dried I then drilled the first one and it ended up with a 13mm ish hole drilled with a 10mm drill. I tried again, and then again. So I bought a stabilised blank and tentatively drilled it with a 6 or 7mm hole before using a 10mm bit. That was about a year ago and its still sat on the shelf!!
Drying them is the easy bit it is preparing them for turning that is the difficult bit. They are too soft to turn unless stabilised with resin to do that you need some sort of vacuum chamber where you can put a container of resin with the cobs inside then vacuum for a while to make sure the resin goes through the cob.
I have brought a few of the ready made ones to turn and lost about 50% of them due to voids etc so not going to bother again, also they dont sell very well.
john
That's a nice looking pen John.
I'm interested to hear they don't sell well. I would have thought they would, if nothing else because it is so interesting to have a writing implement made from recycled edibles.
I may end up scrapping this project and feeding the other blank to the dog :D
nodrog74":22en14id said:
Steve,
Thanks for PM - I could not reply to you directly as I am a newbie.
Gordon
'ere, some bugg.r has nicked my name.
I'm Nodrog, you get your own nick name.
Cheek :shock:
    27.5 KB
