RogerS
You chaps are pretty good at ferreting things out as I am drawing a blank on this one.
I can find composite SCART but not RGB.
Sporky McGuffin":v9m37i8j said:From a quick Google (and some day-job knowledge) I think you're pretty much stuffed I'm afraid.
The screen's native resolution is a rather unusual 1024x852, so even if we found a way of making HDCP unimportant (which is a non-trivial task) you'd also need a scaler as the new Freeview box will very likely be restricted to two output resolutions; either 1280x720 or 1920x1080, both of which are above your screen's native resolution.
Given that it's got to be about 10 years old I think your simplest and least expensive option is to buy a new telly.
