Good afternoon,
I have just got an old wadkin woodturning lathe which is fitted with a brookes 1hp 3ph 415v motor, from what I've found so far to run this motor using a 3ph 240v inverter / vfd I will need to change the voltage to 240v.
The problem is this motor is not dual voltage, it lists just 415 on the plate and has 4 wires within the terminal box, I have read that you can open up the motor and bring out the additional wires to allow the motor to be wired as 240v delta, is this true and is it worthwhile?
If so do you know of any tutorials on this process as I don't know where to start. :? Or is this a common modification that a motor rewind shop would offer for a reasonable price?
I feel that it might be easier and more cost effective to just fit a single phase motor and switch gear.
Thanks, Andy.
Thanks, Andy.
