Hi,
I am not entirely sure if this is the right place to post my question, but my project is still in the design stage (although late in the design stage).
I am going to make some built in wardrobes. I am going to make them out of sheet material (originally planed to do them in mdf, but as the wardrobes are in the kids bedroom i think it might be better to use veneered ply).
I am a liitle unsure to the construction, i was under the impression that i should butt joint the top and bottom panels to the side panels with the side panels overlapping (but not portruding) the top and bottom panels, screwed through the side panels (clearance hole) into the top and bottom panels (piolt holes). Then the back panel overlapping (but not protruding) the side panels, top panel, and bottom panel, screwed through the back into the sides top and baottom panels.
Is this right?
I hope you can help
Is this right?
I hope you can help
