eaglesalz
Hello all,
I have a old Sip compressor has worked fine for many years, dropped a bit of wood on the unloader/pressure switch which broke the plastic cover but still worked for a few more years, but recently it now tries to start, a bit like turning your car over with a flatish battery and then trips the breaker (16amp). Decided to put a new unloader switch on but still the same (do you have to adjust these for pressure?), the only difference now is that it does not trip the mcb but the main switch, the compressor is single phase and the motor is a hawker sidley on the plate it draws 15amps. Would a capacitor on the motor cause this (there are two). Thanks in advance.
