simontheintrepid
New member
Hi all, I’m not an experienced crafter at all but in an effort to tidy up my garage, came up with a design for a bicycle rack that I wanted to make out of ply laminate and have a few questions about how to go about it. I’ve uploaded my sketch below but it is essentially just an oblong with four 90° corners and cutouts on the sides to put the bike top tube into. I also know that I could make this very easily with right-angled corners as opposed to curves, but I was interested in the technique and wanted to make something more aesthetically attractive.
1. First of all is this sensible? The plan is to use 7 x 3mm thick ply and the corners have an inner radius of 29mm.
2. Do I need to buy a plywood specifically marketed as flexible, or does it just have to be thin enough? If so, do you know a good place to buy from (I’m based in Kent)?
3. Can this sort of thing be moulded in stages (i.e. could I make a mould that covers 1 or 2 corners and duplicate the process) or will this get pointlessly difficult with having to glue the thing in stages?
I also know there will need to be at least one join somewhere, but haven’t decided how best to go about it. Anyway, any advice is gratefully received.
So I was going to post images here but for some reason I do not have permission to post images or links, so basically it's an oblong with curved edges (outside radius 50mm), full dimensions are 250mm tall, 350mm wide, about 250mm deep.
