I have been considering buying a circlular saw/guide rail saw system for a while, having used an old Makita 5703 and straight edge up until now. Specifically I am looking at purchasing a Festool TS55 having seen a couple out on site. What sold it was one of the guys using it said it made his planer virtually redundant now when shooting doors.......reckoned it would take as little as 2mm to nothing on a stile no problem and it wouldn't need tickling with a planer after.
However I am also considering adding a Makita 18v lithium circular saw (as well as the TS55) as I already have batteries and charger, as I thought it might have it's uses at times where I might just need to make an odd quick cut. It would save time setting up with transformer (almost all my kit is 110v) , extention leads, etc. I had to do a job the other day in a confined space in a loft and found myself using a handsaw and thought the battery makita would have been ideal.
Anyone use a battery circular as well as a guide rail system, do you find the battery saw gets enough use to justify buying?
Also for those of you using a TS55 how do you find joining the rails, is it easy and are they rigid when done? I know I get a 1400mm rail with the saw but am thinking of adding another rail to join onto this for ripping down 8x4 sheets. I know you can get a single rail long enough to do just this but they are expensive.
