Qwercus
Hi all,
I have a site saw with a blade diameter of 315mm, it gets used for general ripping and cutting firewood. I need to know if I can fit a smaller blade size of say 250 or 200mm safely. The reason I want to do this is that I'm doing a laminating project that involves ripping a large quantity of small stock into thin laths of only 3mm thickness. If I use the larger blade it has a wider kerf and will covert a lot of stock into sawdust!!. The smaller blades will have a narrower kerf and are cheaper to buy so I could invest in a new one. There used to be planer blades that gave a very smooth finish but I haven't seen them advertised lately. Any advice appreciated,
Live long and prosper.
