xy mosian
Hi all,
As a hobby woodworker most of my tools get less use than they deserve, some almost none. Yesterday I dragged my Circular plane out of its resting place to actually use. This about the second time in twenty years or so. I am attempting a curved, should that be bowed, front to a corner cabinet and needed to plane the edges of two of the pieces.
I managed it, using the circular plane, but I cannot say that I really new what I was doing. I think it was more a matter of fiddle until it's right.
Here is what I did. I drew around a template, of the curve, and then cut slightly away from the line with my Jigsaw. Picked up the circular plane and set the curve of the bottom to fit the template. When I went to plane the edge nothing happened. Of course the sole of the plane was touching the timber at each end but not around the blade. The solution was to increase the radius of the sole to achieve a cut and adjust it as I went along.
All in all I think using a spokeshave might well have been quicker. Have any of you experience in using these planes, or a reference to thier best use? I ahve another edge to plane soon and I would like to know what I am/should be doing.
xy
xy
