Chopping boards
Sheffield Tony
Ghost of the disenchanted
2 Aug 2012
Bedfordshire
All this talk of chopping boards over in general woodworking makes me want to show you mine:
I made it from offcuts of 19mm beech. With only hand tools - the planing was done with a Record #5, and was jolly hard work. The grooves/well were carved with a 1/4" and 1/2" gouge, and a crook knife.
The knife is an old Sheffield made one which I gave a new handle, cut from a log in the firewood pile which I liked the colour of, fixed with brass Corby bolts.
Both are finished with walnut oil.
    92.3 KB
Hi Tony
Nicely done, plaining end grain is a work out!
What glue did you use.
Regarding glue - I was going to ask on here, but thought to do a search first. It found 2 or 3 threads discussing exactly that, and the same answer each time - Titebond3. So Titebond3 I used. And what a useful resource UKW is.
That chopping board displays some very highly skilled work. The diligence required to produce even width straight grooves with a gouge, by hand, is tremendous. Then of course the corners turn up, here they are equally as good. As a hand worked piece that looks deceptively simple, but in reality a great deal of skill must have been required, and shown. Well done!
xy
:oops: thank you. I think it is more down to time and care than any great skill or technique; I marked out the edges of the groove first with a mortice gauge and compass for the corners. It's then surprising how easily fingertips can feel the spots where you need to pare a bit deeper.
