Hi - bit of a numpty newbie question would appreciate advice from those with the 'knowledge' (that's you lot!!)
Hand dovetails, saw the angles, fretsaw out the waste (leave about 1-2mm above the line), chisel out the rest of the waste (this is the bit where the pins will go so the bit between the tails) and instead of a nice flat base it seems that the chisel sort of levers out a lump of wood thats broken off below the line.
hard to describe but it's almost like it's pulling out a tooth with the roots. the outside edges are fine but inside the joint is a cavity.
chisel as sharp as I can get it. wood is 10mm thick pine.
is it the wood. me or the sharpening - or all of these?
all advice, as ever, highly welcome
