Hi,
I've got a table saw and mitre saw which I use a vacuum dust collector on which has a power take-off, so goes on/off automatically with the machine operation. I'm going to buy a planer thicknesser and realise I need a proper chip extractor with a 100mm hose. I am wondering if these / any of them also work on a power take off and also only go when the machine does? Also it needs to be small enough to go under a run off table and be as cheap as poss if anyone can help or recommend I would be grateful?
My other thought was weather I could use my existing vac and if there was a cyclone that had a 100mm inlet and vac hose the other way if anyone knows of such a thing? :shock:
