Cherry pot
will321
25 Feb 2011
Cherry pot turned green. Microwaved for two minutes at 800 watts. Finished with Beall buff.
Looks like little pots are your thing at the moment Will, do you turn a lot of Cherry green?
I'm surprised you got away with microwave on full power as all the guides I have read use defrost for 2 mins, leave for 30 mins and repeat this cycle many times before moving on to higher power.
I will certainly try the full power method on something unimportant soon.
Good little pot, I like the shape. Sounds like you were cooking it, not drying it! But it seems to have done the job.
I just turned a cherry vase from a log that was felled only a week ago. I didn't dry it nor did I part turn it but took it straight down to around 3 or 4 mm all over and so far it's survived. I'm leaving it in the workshop for a while to let fuully dry before taking indoors though. I was careful to make the base concave so it won't wobble as it inevitably distorts a bit in the middle.
The pot warped a little after nuking but I like the distortion - it makes it feel a bit more lively. Uniform thickness helps a lot but that length of time is a little risky. The pot was cut from a quarter sawn end grain blank, dealing with the pith in cherry is asking for trouble. By the way, dimensions are about 6 x 5 inches.
I really like the shape and the wood, for some reason I want to pick it up :?:
