AndyG
Hello all,
Well, after a long time away from the forum (a busy time at work) I'm finally back into the garage .
One job that suddenly became top of the 'job list' is a chair repair. However, I wanted to get some advice before starting.
The pictures below should make it pretty clear.
Basically, what I think happened is the glue holding the MT on one of the rails loosened. Then, with successive pulling and pushing of the chair on carpet, stress on the leg finally caused it to break.
The MT repair is fine. I'll clean the glue off, pad it out a bit of veneer and reglue. However, fixing the broken leg is a bit of a concern. The only approach I can think is adding some kind of dowel to provide the required strength.
Any ideas/tips/suggestions would be really appreciated. These chairs have a bit of family history, so I want to make a good job.
Andy
The chair:
The broken leg:
Andy
The chair:
The broken leg:
