Wood spoiler
This started out as tool practice in hollowing.
It started out as a Plane Tree Trunk (Tulipwood - I think?)
Having turned it I came back to find the base severely cracked from drying. I chucked it to one side and carried on with other things.
I moved it a couple of weeks ago and the cracks across the bas had closed themselves. It had stayed pretty much in the round. One inclusion had cracked. I treated that to a dose of CA
Having turned it down again I thought it was crying out for a bit of my carving practice. Conscious of some sage like advice about becoming a "one trick pony" I wanted to try something different with different techniques to those previously employed. I remembered the Green Man, the face looking through the Oak Leaves. I set to and had a go and welcome observations on the finished effect.
I put a walnut foot onto it to finish it off. I was a bit disappointed at how light part of the Walnut came up, but that is the joy of working in wood.
It stands 10" tall and 7.5" wide
I sealed the finished thing with sanding sealer then Beal Buffed it. In the abscence of comment on how to use the Bristle brush, I worked some microcrystalline wax into the carved area and worked it over with the new Chestnut Bristle brush.
So what do you think of it?
