RogerS
Woke up this morning to find the car battery dead as a dodo. Dead as in 3v across the terminals. Wondered as to why and so disconnected the battery and stuck it on charge (although with that low terminal voltage I think its days are numbered).
Next, measured the resistance looking back into the car and got 3 ohms....mmmm..that would explain why it had drained. Bit of Googling and the pessimist in me starts to think the alternator is shot. So disconnect the heavy duty cable on the alternator (not the other smaller cables) and measure again...still 3 ohms...thinks 'alternator OK'.
Remove the plastic gubbins around the battery +ve and see a fat wire (to the starter I am guessing) and also a 60 amp fuse. Remove 60A fuse and measure resistance again. High resistance. Replace fuse and measure again. Still high resistance. Que? I have done nothing. I have not rolled the car forward. Nothing and yet now the resistance has changed (unless the wee multimeter is junk and gave me a false reading).
Don't really understand what is going on here. Reluctant to buy a new battery especially if there is this 3 ohm (intermittent ? how?) load which will crucify any battery.
One hour later, disconnected the charger and measured across the battery which gave 12v....surely the voltage isn't back up 12v so soon (as in an hour) or is it that it might be at 12v but the internal resistance is still very high and so not be able to deliver a full discharge when needed for starting etc.
