Can Festool planer be used instead of a handplane?
Chlad
19 Apr 2018
Cheshire
Looking at the Festool EHL 65 EQ plus and it's got some very good reviews. Can it be used for planing wide pieces of wood (like a hand planer) or is it for narrow wood only?
I use an ehl65 to take the gritty dirt and saw marks off large boards for this it works very well, but once I start to cut down and dimension I then switch to hand planes. Maybe it's my lack of skill with an electric planer but I wouldn't want to use the ehl65 beyond this initial stage; personally I find hand planes far easier.
It is a nice planer but if you try to plane anything wider than the blades you will be left with ridges, I am anyway, I find the same with any electric planer.
It's a good bit of kit if you want to take a lot of material off but I wouldn't bother trying to use it to get a finished surface, you would need hand planes for that to even out all the tool marks and grooves from the power planer.
Having used a few power planers I would say the Festool is only a little better for extraction, power is lackluster, not very robust and it isn't really any more accurate than any other machine. If all you want to do with it is take masses of material off quickly you'd be better off buying something on the cheaper end.
Hand held electric planers are a really crude tool. If they were hammers they would be a sledge hammer, rather than a toffee hammer. You will spend more time cleaning up the mess they've made of the wood than you did in using it in the first place. Think of them as a building site tool, for hogging off large amounts of timber crudely. They aren't a workshop tool. And for goodness sake...........Festool? Really? Why would you want to spend so much money for no extra capability? Why are these things fetishised? Take the label off a Festool planer and try it blind against half a dozen others, and you'd be unlikely to choose it even if someone else was paying for it.
As others have said, it'll remove wood fairly sharpish but not give you a near finished surface. The main difference between it and cheaper versions is the [can't think of the right word; too early] "angled" cutter. If gives a sheared cut like a skewed plane so less bumpy (great for doors). It also fits Festool extractors which is only a bonus if you're into the system.
An erbauer off Screwfix will be wider, cheaper by a mile and not make the wallet weep so much.
I've got an old B&D long bed that is great for hogging material. No good for a finished surface though. It's easy to run over it with a sander or smoothing plane afterwards.
Buy a cheap planer, don't waste your money.
to answer the question yes it can be used instead of a handplane, but it won't replace a handplane, and you can remove a surprising amount of material fast with a handplane.
Don't get me worng, I'm not a brand junkie but I do believe that you get what you pay for. The only Festool tool that I have is a plunge saw and I have to say that it is a pleasure to use. Festool do make good tools. Maybe not all of them are top value for money when compared with other brands but quite a few are worth it. I do agree that Festool are rather premium priced though. The only other tool I am considering from the brand is the OF1400 router as it looks quite decent and gets raving reviews.
screwpainting":2il4v65i said:
This is an interesting video by Lou Suzedde on electric planes and how to set them up. I never knew there was so much to them and have never seen such an in depth explanation on just what you can do with/to them. About 2 minutes into the video...
That video was a pleasure to watch. The guy knows his stuff.
It looks like I am best sticking with my vintage Record no5 jack. In which case I best start getting used to sharpening that blade properly. :mrgreen:
Rough stock removal is what they are best at.
You will still need to hand plane.
Having watched the linked video from Lou the boat builder, I am impressed by his fettling of an electric plane. He has a lot of control, no grooves and a good finish. The blade alteration idea is one of those things that seems so obvious when you know it. And he is using a cheap Ryobi that for various reasons is superior to much more expensive tools. I thought the video was an eye opener and it shows an electric plane can do a very good job if you take the trouble to use the tool to its best capacity.
