Can anyone tell me what this is?
katellwood
2 Jan 2007
Near Dartford, Kent
I pretty sure its linked to gas supply and I would like to get rid of it
I'm not aware of any other property with gas that has one, is it necessary
TIA
I think the left hand one is the toe of a training shoe, the right one looks the same but in a mirrored configuration. If it smells of gas you may have a problem.
Sorry mate, shouldn't extract the michael, us "old Dartfordians"* should stick together.
Seriously, I've no idea except to say the "saucer-shaped" thingy looks like some sort of pressure reducer, so it's gas????? (And that's a DEFINITE maybe) :lol:
* (my birthplace).
AES
AES
I think he may be right.
I'd try turning all the taps off. If helicopters and armed police turn up you can open your own tourist attraction.
Its a gas govenor - your gas supply may be off an elevated pressure gas main. Its for reducing your gas pressure - pipe off the side of it will be the vent pipe and prob a flashback arrestor. It will be made by Bryan Donkin or Jevons I would think.
Not that easy to move
Jimmy
Now what you've got there mate, is a steel plate, an 'ole, and some pipes. Amazing what you get in a lawn, not sure what weedkiller will make that go away...
Hmmmmm definitely a Man Hole of some sort...... hmmmm George Michaels ya man for such things maybe yon Barrymore at a push, do you live near a cottage? 9-)
Build a natty imitation well over it! Or a windmill, or a dovecote, Or you could move house I suppose. :lol:
Every time I want an extension built, Severn-Trent want a new pig-in-manhole put in my lawn! All because they couldn't be bothered to re route the sewer pipe, when the built my drum! :mrgreen:
Best of luck. (hammer)
Can you not specify a double-sealed airtight MH cover in the extension, or is it access they are bleating about?
NazNomad":1v1o6bpz said:
Can you not specify a double-sealed airtight MH cover in the extension....?
Yellow = gas
Looks exactly like what an earlier poster said, some kind of pressure reducer/regulator for someone's supply off a main run.
If the gas leaks, it'll pop off the cover (in an interesting way perhaps).
I think it would be difficult/expensive to get that lot moved, but I wouldn't really want one of those inside my house.
I think you need proper advice on what's allowed/possible from a gas-safe registered person and/or your local gas supplier.
Cheers, W2S
