HeathRobinson
Wood screws are not a subject I have given much thought to in the past ... What? :shock: You didn't think I meant that kind of screwing did you!?
I want to use some screws in the construction of my bench so that I can break it down in the future when moving. The bench is predominantly ply but overall is a mix of ply, MDF and solid wood. I'll describe the scenarios and perhaps those who have the experience can enlighten me as to the proper screw and technique for each scenario. This is the bench I am building.
1. Reinforcing the mortise and tenons in the legs. Legs and stretchers are all laminations of different lengths of ply. Srews will go through the face of ply on the leg and pass through the face of the ply on the tenon. Yes, before the comments from the peanut gallery begin, it is a plywood mortise and tenon :lol: Seemed a simple way to make a sturdy base for a beginner. At this point these reinforcements might not be necessary, I suppose I could even replace the screws with dowels. The mortise and tenons will be glued too.
2. I'm using a plywood panel as a side stretcher. Screwing a the face of the plywood panels into the exposed edge grain of the ply laminations of the legs. Effectively ply face to ply edge. I'm worried that this join will not be secure enough because I'll be screwing side on into the ply laminations and because it might split the ply.
3. I'm going to put solid wood battons along the inside of the aprons that I'll later use to secure the worktop and these battons will be screwed into the ply apron, so through solid wood into a plywood face.
4. The worktop itself is a layer of ply and a layer of MDF. I'd like to be able to keep the two unglued so that I can flip them over at some point. This means using screws to hold them together. So this is a plywood face to MDF face (as if that matters in MDF).
5. Back to the batons for attaching the worktop. I then want to screw the top to the battons installed in the base and this will be a screw going through the solid wood batton up into the face of the ply part of the worktop and possibly through that into the MDF.
6. A solid wood edging around the worktop. All screws will go through the face of a piece of solid wood but will be securing that to either the MDF layer of the worktop or the edge of the ply layer.
I plan to countersink all of these screws and would also like to know if there is any science to creating counter sinks? Or are they all pretty much the same and I can get away with any counter sink bit?
PS. Woodbloke, the plan is to pop a solid bit of worktop on top of this worktop as suggested by you when I first came around for assistance with my woodworking woes I still have the plan you drew. Only the base is different in this design.
