I want to fill some recesses with a contrasting fill- i have in mind brass filings, brass powder, or turquise powder.
The recess is veneer thickness- 0.6mm and a couple of square inches in cross section. Ideally I dont want to have to do too much sanding afterwards for fear of going through the veneer, but a dremel attachment might be pretty accurate on just the fill.
When complete, it will not be under any stress and cant actually physically fall out. It will also be laquered over the top.
having never done this before, will I get away with dripping thin CA on it or do I need to use epoxy? Can I get epoxy in small quantities, i only need to do about a dozen of these items.
