Burnisher use
xy mosian
21 Feb 2009
West Yorkshire
Hi all,
Yesterday I came across one of those eureka moments. I was shown to use a ticketer, sorry burnisher, on the scraper dry. This has always been a bit of a drag at high pressures. I don't know what made me do it but yesterday, when I came across the drag I instinctively reached for the butt end of the candle. A rub along the burnisher and what a difference. The first stage hook turning was easier and, although I have no real proof, I get the impression that the edge is more even and perhaps sharper.
If you don't lubricate when burnishing already give it a whirl.
xy
They used to say wipe it on the side of your nose or behind your ear before using it.
I find a smooth burnisher works better, and a smaller diameter one helps.
xy mosian":3jmfd3gh said:
Hi all,
You (really) don't need high pressure. My eureka moment was using a (much) smaller burr. A large burr
is only needed/desirable when ripping off old varnish.
With lower pressure the need for lubrication is reduced, although many old book recommend a drop of oil.
BugBear
Thanks gentlemen,
If I had come across the lubrication of burnishers before, then I had forgotten it. As for the various body extras, I think I'll stick with the candle. My burnisher is polished with the same regeme as my carving tools. A tickle with the diamond embedded rubberised wheel and then a few minutes on the buffing mop. Not that it needs doing very often, but I always feel better having done it.
Bugbear I am beginning to see the same as yourself, a good sharp, small, burr is better than a big blunt one.
xy
