Brazing flux
Sheffield Tony
Ghost of the disenchanted
2 Aug 2012
Bedfordshire
Are there any easy ways of removing the residues of brazing flux ? I'm using the pink Sifbronze stuff. It leaves a hard, glassy residue which is a s*d to scrape out of corners etc. Perhaps I'm missing something.
You should be able to remove the flux with hot water. most fluxes are designed to meet AMS 3410 and AMS 3411. This means they are soluble in hot water, so put it in a tub cover with hot water and then just scrub until the flux comes off.
hth
edit - forgot to put a link to some info:-
http://www.lucasmilhaupt.com/en-US/abou ... e-cleaning
If hot water doesn't work, try a caustic soda solution - I think the pink stuff is mainly boric acid. Not sure though, but it's worked for me with stubborn high temperature fluxes.
Rob.
About 10/15 seconds after brazing use a wet cloth, the shock will crack the flux and it will fall off. Or a wire brush.
