We're all assuming it's evenly dried, but you've told us nothing about how it was being stored when it took on its present shape.
If - for example - it was leaning against the wall of a garage, with bright sun shining on one side, then it's just possible that the sunny side has dried more than the back and so shrunk, causing the problem. So it would be worth turning it round and getting the back dried out the same.
Or maybe the long side has been allowed to get wet? Try wetting the other side, then letting it dry out evenly (ie put it horizontal, well supported, under cover but with good airflow all round.)
Whatever the case, if you don't need to use it immediately, it might be worth some experiments.
