I have just about finished the bench for my metal working lathe. it is a simple affair but is strong, wooden and has a thick dense top. It is sat on some adjustable feet made using carriage bolts and hockey pucks.
I was planning on bolting down the lathe, because i just assumed that is what you needed to do. But, I have noticed an issue. The headstock is threaded underneath, but on the tailstock end of the bed, the single threaded hug has been snapped.
It is a Boley 4L, and it is too much for me to lift on my own- it must be in the region of 100kgs i would imagine. I plan to use it for making pens- so no large out of balance pieces. I dont think that there is enough meat in the cast iron to drill and tap another hole.
Does the lathe need to be bolted down?
If it does, could I get away with epoxying a plate to the foot and bolting down through the bench. I could do the same to the headstock end to keep it level.
Any better/other suggestions?
