Benchwayze
Having had my existing power screwdriver expire I was in the market for a replacement.
I chose the Bosch IXO Cordless Lithium-Ion Screwdriver.
http://www.amazon.co.uk/gp/product/B003 ... 01_s00_i00
I went for this particular model, having been impressed by one or two other Bosch tools I have bought lately, from their 'Professional' range.
I had used Bosh power tools before, and I still have one of their early, upright 1/4" routers. But the smaller tools I 'd used (Screwdrivers, drills) were not quite up to the same spec. But it seems Bosch is getting its act together.
The drill comes in a tall, oval tin box, unusual, and for me a bit of a disappointment. ( It resembles a toffee tin!) It looks fine, but takes up shelf space. However, if you don't want to lose the two angled attachments, you need to keep the box, because there is proper storage inside for the attachments. There was a bit of a puzzle/test to open the box. At first glance, what I thought was the lid, wasn't, and eventually I clocked that the tin separates into two halves, to get it open. Maybe you won't have the same trouble. I blame my age!
The range of bits supplied is adequate, but there is only one 'slotted' driver. This is small, and just about works in a No. 8 screw, but it jumps the slot unless you take care. So the kit would be improved by a bigger range of slotted screw-bits. For the regular retail price, I think Bosch could have supplied them TBH. These bits are available after-market, if you don't already have some.
There are two angled driving attachments, included in the box. I see these as being invaluable when installing drawer slides and adjustable cabinet hinges for instance. The adapters are simple to fit, at any angle around the 'clock' face of the nose. Just pull off the rubber nose-cap, and you're ready to go.
This drill will handle Kreg screwdriver bits, but it might be necessary to fit an added adapter. The one I used was from my Black & Decker 14v cordless drill.
This compact little driver is surprisingly powerful for its size. There is ample torque, (Enough to surprise me, on first use, by almost twisting my hand over when it pulled up a No. 8 screw.) The drill stows in its charger, on the bench if you wish, and is always ready for use. The charger gets warm, so I wouldn't leave it on charge overnight. However, it's been fine through the day, just sitting there, and it stops charging when it's full and ready!
For a bench-ready, electric screwdriver, this mighty-atom fills the gap between a normal cordless drill/driver, and the full-on, cabled electric drill.
I am well satisfied with this handy little tool. I suspect you will be too. (It's much cheaper from Amazon at the moment, and free delivery meant waiting only about 4 days.) !
(The pictures read backwards, so you might want to start at the bottom and work upwards!)
This is my honest assessment of this power driver. I wasn't disappointed and I don't think you will be either. But for the oversight on the lack of slotted driver bits, I'd say *****, but because of that omission Four and a half.
I commend this little gem to the house!
ll
ll
