Bosch GCM10 SD adjustment of rail system help
Phil_01
New member
14 Sep 2012
Mansfield
I've just purchased the above saw and noticed a slight play and rocking in the blade and handle section. I think I need to adjust the two bolts on the rail to eliminate it. Does anyone have any experience in this matter?
Thanks, Phil.
Bradshaw Joinery
13 Mar 2012
Market Harborough
just put a allen key in the grub screw then undo the nut, and tighten the grub screw. hold the allen key in position while retightening the nut.
doesnt matter if you gotoomuch just unndo and re-attempt.
Phil_01
New member
14 Sep 2012
Mansfield
Thanks for your reply it's greatly appreciated. If I were to over tighten or under tighten the bolt, would this potentially make it worse? And just to clarify are these the bolts that run parallel along one of the rails?
Thanks, Phil.
