Budwozza
Hi All,
I cut this pattern today and used 3 blades - and really struggled to finish it with the third blade, (the blades start to wander and require more effort to feed the wood).
I was cutting a 19mm Poplar board stacked on a 19mm Mahogany board (so 38mm total thickness), both boards were taped together with making tape and covered both sides with clear packing tape.
I was using Flying Dutchman Ultra Reverse number 5 blades.
Does that sound about right for blade use or is there something I can do better - saw speed, pattern feed speed etc?
Regards,
Budwozza.
Regards,
Budwozza.
