Blade for cutting kitchen worktops
cult
27 Sep 2017
northern
Dont have the money to invest in a plunge saw so just looking a blade for my hitachi circular saw for ripping through kitchen worktops. Any recommendations.
Kitchen worktops traditionally are cut with a 1/2" plunge router as they make a better job of it with less/no chipped edges, taken in 5:10mm passes they are much better than any type of saw.
Mike
Mike
i will be using the 1/2 inch plunger for cutting the mitre. The blade is for cutting the straight line at the ends. Maybe ill use the router aswell if its better.
I assume you are using a jig for the masons mitre, in which case the jig can also be used to cut the scribe for the end into a wall or just for the free end, IMO much better and risk free than a circular or plunge saw.
Mike
Mike
Broke my last jig so going to buy a new one. Since i would only use it once a year if even, i dont know what one to buy :( . Dont want to be spending ridiculous money on one
If you do use your circular saw remember to flip the worktop so there underside is facing up as you'll get a nicer finish underneath
Isnt that so the blade digs into it rather than blowing out from behind
Exactly, so the tear-out will be on the top surface
cult":2mqjxauz said:
Mike
Travis Perkins and I am sure others hire them out.
Mike
