Fizzy
Hi All
I have a Ferm biscuit jointer and was looking to fine tune the depth the blade cuts when cutting say a size 20 biscuit slot. After the cut was made I used to have a gaping hole that nearly swallowed all the biscuit :shock: but after a bit of tweaking I have got it to 2mm between the lines when putting the biscuit in both ways and drawing the line showing what is sticking out (does that make sense)
What size should it be :?:
Hope to hear from someone soon Cheers
