Not sure if the right place but here goes.
We have UPVC patio doors and these will be replaced with some wooden bi-fold doors. The hardware i would like to use hangs the doors from a channel fitted to the head of the frame.
I was planning of screwing/bolting a peice of 25mm plywood to the underside of the lintel into the brickwork and then fixing the frame to this. Does this sound like a silly idea? Is the lintel going to be strong enough to support the doors and frame (3 leaves, 2100mm O/A width x 2000mm high).
The house is around 8 years old, i couldn't tell you what type of lintel it is.
