chippy1970":3depgw7a said:
Oh sorry I thought easily applied implied that I didn't have a spray gun. Hope this is enough info for you
It wasn't for me, as spraying is probably one of the easiest ways of applying a finish. The additional information helps because now I know you aren't needing to finish wood to withstand, for example, a high moisture environment, eg, some bathroom and kitchen scenarios, or high temperature/ low RH circumstances such as a south west facing conservatory. And because it's a bookcase I am able to assess that the surfaces won't have to withstand the typical high abrasion and surface damage that coffee tables and dining tables have to endure. I hope you can see that your original question omitted some key bits of information that would have helped someone give a considered response.
For a tough and durable finish you could use oil based polyurethane varnish applied with a brush. Characteristics of this type of finish are that it's slow to dry and likely to attract dust and other contaminants during the drying. It also changes the colour of the wood significantly. And because it's very slow drying, it can literally take weeks to fully cure meaning the bookcase would really be unusable for a long time: if books are loaded too soon after finishing there's a good chance they will stick to the varnish. So, probably not a great choice for your project.
I think you are likely to get better performance out of the water based finishes, and Jason's suggestion of Aquacote I think is a good one. Another one you might look at are the products by Bona-- see here:
http://www.bona.com/en-GB/ Have a look at their Mega, Naturale and Primer Amberseal water borne products. You use similar equipment and methods for these as you use for the Aquacote Jason suggested. As to their proper usage and application, just follow the instructions on the can or provided in their MSDS and their technical data sheets, etc.
Finally, you might even have a look at the water based 'varnishes' supplied by the sheds like Homebase and B&Q, and specialist paint stores-- they're not bad at all if the wood is prepped properly and the finish applied correctly. Slainte.
