I said in someone else's topic I needed to get some practice with my turning, so here's some of it.
Comments welcome and before anyone else gets it in, I still need more practice :lol:
These are (will be) a pair of candle sticks.
The "heads" are scraps of idigbo, oak, beech and a strip of utile all glued together on oak stems. I have no idea what I'm going to use for a base yet, they were and exercise in repeatability.
This will be the centre portion of a leg for a new pedestal table I intend on doing in the near future. I have a MK 1 table in the process, see my earlier topics, but I'm getting ready for Mk 2. It is oak, three sections glued up as one. It's approx 380 mm long including the tenons and approx 90 mm diameter at it's width.
This one's self explanatory. It was some old Mahogany window sill.
The good lady wanted something simple for one of her candles. It's mainly oak scraps with a little beech thrown in.
She wanted something really chunky as the candle is 3" wide. She drew it and I made it.
It's not at all complicated but the grain and colours make it quite pretty.
And to the last. Some of you may have seen the small pedestal table I made a little while back, well the top didn't work out at all. It split at the joints and failed. Moisture, movement and inexperience in short.
The top had a short life as a frisbee and boy did it fly down the garden. Due to the way I had made it up I ended up with eight triangles of oak. Glued seven of them together, screwed it to the face plate and made it into another candle stick/holder. Had a very nasty catch which left a bad mark. So I drilled a hole in it and cut off a few inches off the broom handle, that explains the "dot".
Thanks for looking.
Thanks for looking.
