Bangles.
Paul.J
27 Sep 2006
Birmingham/England.
I have been meaning to have a go at doing Chas's bangles for ages so when Chas said have a go and i was given some off cuts of Walnut i thought i would,so found some Ash out taht i have had for years so well seasoned and these are the results,so far :wink:
I managed to get twelve glued up with what i had,some Beech and Walnut so will finish those anotehr time.
these are 65-70-75- and 80mm inside dia,think i might need a 60mm for smaller wrists.
I use Titebond II to glue the parts so hope taht is strong enough??
    23.2 KB
Thanks chaps :D
gregmcateer":128nfnwr said:
They look lovely, Paul.
Have you done a WIP?
Greg
I think Chas has covered this some where on here.Only difference is i used teh table saw rather than a chop saw.
I will do a WIP next time i cut some parts up :wink:
Presume Paul uses a similar method to This (Bangles) (Only difference these days is I don't sand, stock prep closer & Chop saw cutting more accurate with practice)
Take care if gripping segmented stuff in expansion mode as shown above slim wood sections and glue joints are no match for a scroll chuck.
Yes you will - I've made bangles in the past and I have small hands - 60mm is perfect for me :)
Cheers Kym.
When i made a load of bangles last time,which was some time ago now,everyone wanted the larger sizes,biggest i made was 90mm :shock:
The smallest i can do with this batch is the 65mm so will have to cut some wider parts for the smaller ones.
