Quantcast
Bandsaw won't cut straight
Satinseat
10 Feb 2020
Peterborough
My old draper bd250 has started to cut to the left, and won't cut straight.
Looked at set up but can't find the reason. Any ideas please. Thanks.
sunnybob
software developers nemesis
11 Oct 2014
cyprus
always assuming....
A/ You havent bashed or bent anything on the machine.
B/ The bearings do NOT squeeze the teeth when you push the blade back as far as it will go (top and bottom set).
C/ You havent cut a thousand circles going all in one direction.
D/ You havent got lazy and are trying to push the wood into the blade too fast.
The blade is just worn out. 8)
MikeG.
Plodding on.
24 Aug 2008
Essex/ Suffolk border
Always, always always suspect the blade before you suspect anything else when it comes to bandsaw issues.
D_W
24 Aug 2015
PA, US
If you've got another blade on hand, try it first. Suspect damage to the tooth set as others, or just dullness causing thrust on the blade and thus shoving the front to the side as the pressure is too much to get into the cut without strain.
