Bandsaw Blade Brazing
ydb1md
6 Apr 2005
Maryland
I'd like to make my own bandsaw blades -- I just purchased a blade that's too long and I don't want to return it.
I have a small welding/cutting torch rig that I've never used. What do I need to do to braze my own bandsaw blade?
MikeW
15 Apr 2005
Forest Grove, Oregon USA
Hi Dave,
You need to file the ends--after cutting to length--very square. I used an acid flux to clean and silver solder. You don't need really high heat.
You will also need a facility to hold the ends together very straight and square to each other. The link below is to Woodcraft's kit, which should give you an idea for making a rig to hold the bands.
Take care, Mike
http://www.woodcraft.com/family.aspx?DeptID=2125&FamilyID=4491
