mikebarnes0_0
Its fairly simple to calculate the projection of a tool to be honed from the front edge of a honing guide in order to achieve a specific angle. The table below is only appropriate for the Axminster de luxe honing guide (to nearest millimeter).
Deg mm
25 51
26 48
27 46
28 44
29 42
30 40
31 38
32 37
33 35
34 34
35 32
The formlula is easy to use in a spreadsheet for any guide.
Height, from bottom of roller to top of support plate/SIN(Required angle*PI()/180) then deduct the distance from the centre of the roller to the front of the support plate.
It is easy to make a jig to measure the tool projection and set the tool square.
Deg mm
25 51
26 48
27 46
28 44
29 42
30 40
31 38
32 37
33 35
34 34
35 32
