Honest John
After purchasing and watching Steves complete bandsaw DVDs I've now got my old SIP 14inch bandsaw cutting true and running very sweetly. I've even tuned out the drift following Steves instructions! The week spot of my saw now is clearly the rip fence, which may or may not lock true to the blade when moved. I don't think any amount of fettling will significantly improve this and I am thinking of an upgrade. The Kreg and the Axminster are both in my sights. Both of these fit to the front edge of the table. The standard SIP fence fits from underneath. There are several options, but the Axminster instructions say to drill and tap 2 M6 holes in the front edge. This looks possible but will mean drilling 2 5mm holes 23mm down from the surface of the table. This will put these holes towards the lower edge of the casting, or at least not in the middle. The casting is a little over 8mm thick at this point. I'm wondering if a 6 mm clearance hole through the casting and using a nut and bolt rather than tapping the hole would be a better solution. I'm thinking that I could place a section of steel bar between the casting and nut, thus spreading the load along the edge of the casting. As I understand it once fitted these bolts will not be undone. The rail can be removed by undoing the knobs at each end when the blade needs changing. I think the Kreg version fits in a simolar manner..
So, has anyone fitted either of these to an SIP bandsaw, and do you think that a nut and bolt with load spreading backing plate would be a good idea?
