trojan62
hi all
i recentley bought this new Axi lathe and its great, i had it on the stand but i seemed to get to much wobble and vibration.
in the end i took it off the legs and mounted it to my bench, which has proved much better.
my question is, is that now the axi is bolted to the bench its a real pain trying to swap the tool rest holder around to have it for outboard turning when the head is swiveld.
what i mean is, on the stand you just reached underneath and uscrewed the banjo and swapped it to the other side of the headstock, but now its bench mounted i cant really get my fingers in the bed slot to undo or tighten the banjo.
has anyone who has the axi awsl1000 had similar problems.
i know i could lift the lathe higher on blocks to get my hands underneath but i really wanted the lathe directly bolted straight down on the bench.
all help appreciatted.
thanks...
chris.....
thanks...
chris.....
