OPJ
I came up with this idea a few weeks ago while staring blankly at my machine (Axminster AW106PT) while it was set up in thicknessing mode. Like several others on the market, this model is one where you need to remove the main fence from the top of the machine in order to access the thicknesser below. This has always presented with it the problem of storing the fence elsewhere in the mean time. Usually, it ends up on either my table saw, bandsaw, mitre saw or workbench. Wherever it goes, it always ends up getting in the way!
My solution didn't take more than a couple of hours to produce:
All I've done is replicated the main mounting bracket using offcuts of wood:
This is bolted to the removable casing on the back of the machine and the fence simply slots in to place.
There is one additional advantage to this arrangement - I can use the inverted fence as a place to stack timber waiting to go through the machine! :wink:
While this doesn't eradicate the need to remove the fence, I think it could prove to be quite useful, even if it does increase the footprint of the machine.
Thanks for looking. Hope the idea may be of use to some.
