Attach wall relief flat to wall?
Chris152
26 Apr 2017
Cardiff
Any thoughts on how I can attach this flat to a wall?
For the photo I used panel pins but that's not very secure. I want the attachment to be invisible and allow for some adjustment to achieve horizontal.
Thanks for any thoughts,
Chris
    158.2 KB
Rare earth magnets in the piece, and screws with eccentricly ground heads in the wall?
nev":7u9esb5y said:
Keyhole hangers
Keyhole bit for router or drill
anything on this page
Long screw from other side of wall :)
Slightly off topic but I got carried away when I discovered toolstations escutcheons made good key hole hangers.
I forstner bit them in flush, job done.
Thanks all.
I like the idea of a horizontal slot which allows the wood to be shifted left or right, allowing for perfect horizontal balance to be found. A single point to hang is difficult to establish as it's not evenly balanced, and if I put two in I'd need to get the hanging points spot on first time or it'll be off/ drive me mad.
Could I route a hole and insert one of the ones with horizontal adjustment from this page to achieve that? (I don't have a router but maybe it's time to take the plunge...)
nev":1v8qij5w said:
Chris152":3b2ntn4f said:
Thanks Nev.
Do you think one of those Katsu/ palm routers would do the job?
Never used one (or even seen one) but the keyhole bit is only a small bit so shouldn't present too much resistance as you would effectively plunge drill a hole and then route (move it) only 10-15mm?
You'd need to make sure that the palm router can be plunged, i believe there are additional bases available.
I imagine one could use the keyhole bit in a pillar drill too because of the small amount of wood to be removed?
