I have just had a dimmer switch installed in my dinning room, the only problem is that it buzzes, the higher the light brightness the loader it is.My electrician says this is normal, I find that hard to believe.
Is he right?
Is he right?
Waka":lqf2rfja said:I have just had a dimmer switch installed in my dinning room, the only problem is that it buzzes, the higher the light brightness the loader it is.My electrician says this is normal, I find that hard to believe.
Is he right?
As I understand it, dimmer switches don't work well with the new bulbs. I had dimmers in most rooms with the old bulbs without problems, but since the intro of the newer type of bulb, I've done a Waka...gone back to switches - RobSteve Maskery":1eqs4r9e said:I had one in my last house. It didn't buzz at all, but it did use old-fashioned tungsten bulbs.
S
woodbloke":296f90bl said:As I understand it, dimmer switches don't work well with the new bulbs. I had dimmers in most rooms with the old bulbs without problems, but since the intro of the newer type of bulb, I've done a Waka...gone back to switches - RobSteve Maskery":296f90bl said:I had one in my last house. It didn't buzz at all, but it did use old-fashioned tungsten bulbs.
S
Paul Hannaby":17krigqv said:Assuming we are talking about the usual filament / incandescent bulbs (most dimmers don't like the low energy fluorescent or LED bulbs), the bulb doesn't flash 50,000 times a minute. The supply is 50Hz so at best, the bulb would flash 6,000 times a minute (50Hz x 60 seconds x 2 for positive & negative cycles). In practice, the bulb doesn't really flash because to do so, the filament would have to go from hot to cold on each cycle to do so.
Register today and take advantage of membership benefits.
